GLR
dudi06
Petroleum
If water cut and GOR are given how to find out GLR and oil saturation???
This one feels even more like a homework question than the other one. I don't think it will be here long.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
dears,
well keep tripping due to underload even Pip around 800 psi,and pump discharge pressure around 33200 psi.the well equiped with AGH.GOR around 45%.
well choked down to 6mm and ESP pump speed to 65 HZ,but the same issue there.
Casing pressure around 250PSI.
sometimes no flow comes out from sample point after 4 hours running time.
any further data i will submit.
any ideas???????????
Please start your own thread and don't start a new discussion on the end of an old one.
If written English is not one of your strengths, there you can get translation help from forum1529 I'm not qualified to help much there, but others seem to do a great job.
David Simpson, PE
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
