Glasses strenght
KFrenos
Automotive
DE
What is the relationship between cost and resistance of the following glasses?
- 5 mm tempered glass + butiral sheet in one side
- 4 mm tempered glass + butiral sheet + 4 mm tempered glass
Can I obtain data about these two different glasses (differences if you use a single glass or a double glass,
resistance curve evolution to break increasing the width,...).
Could it be of help to specify a little bit?
Do you think to have the foil not covered on 1 side
or is that wrong? In general it doesn't seem appropriate to not cover both sides of the foil. The foils's resistence is not strong enough. On the other hand the foil is not transparent in i'ts originl state (before autoclaving)
