metalman8357
Materials
Hi All,
I recently conducted testing with 1/8" fiberglass laminates to determine the durability of this material in sea water. We first conducted tensile tests at room temperature on the material as a control, and then immersed some samples in salt water for 1000 hr. We found that the samples in salt water had 50% of the tensile strength and % elongation when compared to the control samples, but had almost the same modulus. So basically the samples maintained the same stiffness, but lost half of their load carrying capacity and became more brittle. Does anyone have an explanation as to how this could have happened? What is the mechanism at play here that is causing a reduction in strength? Is it the resin that is being attacked, or does the saltwater reach the glass and affect the fibers? Any insight would be greatly appreciated.
Thanks,
M
Thanks,
M
