Gland seal condensers
SENGUTTUVAN
IN
In a turbomachinery , for gland seal condensers do we need to provide vapour and liquid space in the exhanger shell?
With steam and air temperature of 245 deg C and cooling water temperature of 32 deg C , is it advisable to go in for fixed tube sheet design?
Depends on where you are draining the liquid to and if you are wanting to sub cool it or not. If not, then all you need to provide for is the liquid to be able to reach the drain as quickly and easily as possible. If you are trying to sub cool it then you have to provide for the level necessary to get to the degree of subcooling that you want to do.
The gland seal condenders that I have had experience with have all had fixed tubesheets.
rmw
RMW
The turbomachinery I am refering to is only steam turbine and it is for gland seal condenser for the steam. Pl advise.
Seng..
You may find more information if you search and ask using the term "gland steam condenser"
-MJC
