Getting forrtl: severe (24): end-of-file during read, unit 8
LongLe
Specifier/Regulator
My FEA software crashes every time I run a mechanical event simulation. See attached pic showing error message. It has no problems running static analysis. I have attempted running a tutorial file included with the install to determine if the problem was operator-error on my part and had the same error message come up.
I am running Windows 32 Bit
Longle,
It should work if you use administrator on your machine.
I have a similar error (shown at bottom) that I received after installing on a new quad core. The analysis worked before on the old machine, and it apparently works for my Algor rep.
I believed it must be an installation issue. I re-installed it and I still get the same error. I am an administrator on this machine, so that isn't the solution.
Please let me know if any of you have resolved this.
forrtl: severe (39): error during read, unit 40, file C:\I3508P_Leavitt_ROPS_2\FEA2-I3508-0000.ds_data\5\ds.ssc
Image PC Routine Line Source
arun4.exe 0000000140DDCBF4 Unknown Unknown Unknown
arun4.exe 0000000140DD840D Unknown Unknown Unknown
arun4.exe 0000000140D7AFDE Unknown Unknown Unknown
arun4.exe 0000000140D64645 Unknown Unknown Unknown
arun4.exe 0000000140D63AE5 Unknown Unknown Unknown
arun4.exe 0000000140D3C0D3 Unknown Unknown Unknown
arun4.exe 00000001406DAAD2 ELCAL 620 xelcal.for
arun4.exe 0000000140355090 FMAIN 613 yapak4.for
arun4.exe 00000001407A0072 MAIN__ 367 fallocn.for
arun4.exe 0000000140DE51B4 Unknown Unknown Unknown
arun4.exe 0000000140DB7FB5 Unknown Unknown Unknown
kernel32.dll 000000007773BE3D Unknown Unknown Unknown
ntdll.dll 0000000077946A51 Unknown Unknown Unknown
I forgot to mention that I am using a 64 bit machine. Also, I tried the Regall.bat and got several "Access is denied" sequences when I run it, then it errors out.
I just talked to Algor and they said try installing it on a different machine because they said it soulds like the Softweare install is corrupted and if a re-install didn't fix it then try installing on a different OS
I discovered a solution to my error. I turned off User Account Control (in Vista) and now I can get the model to analyze. User Account Control usually prompts for permission to make any changes in Windows system files (or System32). I suspect that Algor is using the Windows System32 folder for some files during analysis. When I try to run an analysis with the User Account Control on, I get the error without any request for permission.
To remind you, I have been logged on as an administrator throughout so I don't know why I am being asked for permission.
Anyway, I turn off the User Account Control and it works for me.
So I ended up building a new machine and doing a fresh install of everything including FEA...so far so good...
New Specs:
Microsoft Windows XP 64bit
Intel Core i7 920 Overclock to 3.4ghz
12 GB DDR3 1600mhz
ATI FireVL 5100 (not sure if this is powerful enough)
Thanks for all your help and advice Guys!!!! You are the best :-)
ok sooo a rebuild didnt work....I found the cause tho... Kinda of wierd...It was a group policy issue with Active Directory. Even tho my account was a part of the local admin group I was still unable to run it. I even ran Filemon and Regmon to try and track down if its something im getting to denied to, no luck there. As soon as I moved my user account into the NO GPO group. and Try running the MES Analysis agian works. So I have to review the GPO applied to the engineer OU. Well That resolved the issue for me...hope that helps out someone else as well.
