Get the linked document from drawing view (Drafting)
Maddy02
IN
I've a view (generative view) linked to a product
Im trying to open this Product Document from the generated view.
Note: view is generated from one of the Enhanced Scene.
Product Tree Structure is as below:
|- Product
|- Part1
|-Applications
|- Scenes
|-Scene.1
When i use the following method it fails -
Set oLinkReferenceProduct = View.GenerativeBehavior.Document '--------> Works gives back the scene.1
Set oLinkReferenceProductParent = oLinkReferenceProduct.Parent '-----------> Gives Scenes Collection
Set oDocLinked = oLinkReferenceProductParent.Parent '-----------> ' Returns object i.e Technological object.
Set oDoc =oDocLinked.Parent '--------------------> Fails
or
Set oLink = oView.GenerativeLinks.FirstLink --------> Works gives back the scene.1
Set oLinkParent = oLink.Parent --------> Works gives back the Scenes
Set oLinkParentParent = oLinkParent.Parent ------> Gives back object i.e Technological object.
My question is how to get the parent document through view in this case?
Hope to get a valuable feedback on how to go ahead.
Maddy
Something like this (you need to have a drawing view activated, is not working for unfolded views) ?
Code:
Sub CATMain()
Dim drawingDocument1 As Document
Set drawingDocument1 = CATIA.ActiveDocument
Dim drawingSheets1 As DrawingSheets
Set drawingSheets1 = drawingDocument1.Sheets
Dim drawingSheet1 As DrawingSheet
Set drawingSheet1 = drawingSheets1.ActiveSheet
Dim drawingViews1 As DrawingViews
Set drawingViews1 = drawingSheet1.Views
Dim drawingView1 As DrawingView
Set drawingView1 = drawingViews1.ActiveView
drawingView1.Activate
Dim FullName
FullName =  drawingView1.GenerativeBehavior.document.ReferenceProduct.Parent.Fullname
Dim Box, Speicher As Long
MsgBox "Path and File:" & Chr (13) & Chr (10)  &  FullName  ,64, "LINKED TO"
End Sub
Fernando
Hi Ferdo
Thanks for reply,
Tried with you code but still getting the same error as earlier (attached error snap and links for reference).
Somehow i wasn't able to get the document link from the view so that i can open the document thro' macro.
Maddy
 http://files.engineering.com/getfile.aspx?folder=17e42505-2622-44de-9a31-371090e706f2&file=Untitled.jpg
Hi Ferdo
Thanks for reply,
Maddy
 http://files.engineering.com/getfile.aspx?folder=b941581a-fd13-412e-9672-a088cae9a277&file=Untitled.jpg
Got the solution.
Upon restart both methods works and think some thing in memory was obstructing the method.
Set oDocLinked = drawingView1.GenerativeBehavior.document.ReferenceProduct.Parent '(Works when link points to model directly)
Set oDocLinked = drawingView1.GenerativeBehavior.document.Parent.Parent '(Works when link points to a Scene)
Sometimes mind gets nowhere.....
Maddy.
