Get angle
theing
New member
Mar 5, 2014
18
hi everybody, i am new in this, and i am learning,
i need to get the angles of a surface, i have the following code
Sub catmain()
Set objsel = CATIA.ActiveDocument.Selection
objsel.Clear
objsel.Search "Type=Topology.Face,all"
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set Selection = partDocument1.Selection
Set ref1 = Selection.Item(1).Reference
Set spabench = partDocument1.GetWorkbench("SPAWorkbench")
Set mymeas = spabench.GetMeasurable(ref1)
On Error Resume Next
Angle = mymeas.Angle
MsgBox Angulo
End Sub
the msgbox is empty, and i dont know what am i doing wrong,
i hope anyone can help me out with this,
Thank you for taking the time reading this.
You are checking in MsgBox for Angulo and this is not evaluated in the code....probably should be Angle? And why are you searching for all faces when you need first one in selection (Selection.Item(1)) ? Is easier to tell the user to pick the face and use user selection...search the forum for some examples and also check the v5automation.chm file.
Fernando
hi ferdo, thank you so much for taking the time reading my issue,
i already change the msgbox and still giving me nothing,
and i search for all the faces because i thought that the faces needed to be count previously,
never mind i just did it, the thing is that is no giving me anything with surface, i dont know is that the way it should be, but it is giving me an angle with an edge, so i guess i will have to evaluate the edges, here is the code i have:
Sub catmain()
Set ref1 = objsel.Item(1).Reference
MsgBox Angle
End Sub
Of course
Code:
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Clear
Dim InputObjectType(0), Status1
InputObjectType(0)="Edge"
Status1=selection1.SelectElement2(InputObjectType,"Select 1st Edge",false)
If Status1 = "Cancel" Then selection1.Clear: Exit Sub
Dim reference1 As Reference
Set reference1 = selection1.Item(1).Reference
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = productDocument1.GetWorkbench("SPAWorkbench")
Dim TheMeasureable
Set TheMeasureable = TheSPAWorkbench.GetMeasurable(reference1)
selection1.Clear
Status1=selection1.SelectElement2(InputObjectType,"Select 2nd Edge",false)
Dim reference2 As Reference
Set reference2 = selection1.Item(1).Reference
msgbox TheMeasureable.GetAngleBetween(reference2)
End Sub
Fernando
