TVP;
Very interesting because my source for the information was from an EPRI Report Volume 1, "Weld Repair of Steam Turbine Discs and Rotors" TR107021 V-1 3963 in my possesion. I suspect they cross referenced the HP rotor disc steel with an LP rotor disc steel in the Table. There is a reference to HP rotor steel as DIN 1.6946 30 NiCrMoV5 11, which is under low pressure disc material. EPRI lists 30 NiCrMoV 4 11 under LP rotor disc material and this would make better sense for the higher nickel content. Can you check on this?
