V
vastzor
Guest
Hi
I just had a 3D laser scan done on a former. The scan is an IGS file. When I load the file in CATIA v5 release 17 and attempt to edit the file I get the message "the current in work object isn't a body" The reason I am getting this message is because the file has a geometric set which is made up of over 400 surfaces. Is there any way to transform all these surfaces into one surface. This way I can edit the whole former in one pass as opposed to one surface at a time? I added the string V5V17MaxSimplif=1 to my environment file but to no avail.
Thank you for your time.
