miko20001999
I design a square footing 24in by 24in for a power generator W=220lbs the dimensions are 61*61*40 (in) and stands 3-4 ft of the ground but I’m not sure if I’m going to have problems with overturning or sliding? How can I check if my 24in by 24in square footing will be ok? Also the depth of height of my footing is 6 in.
Thank you
Thank you
