rixtalbert
Dear engineers;
If there is anything such as short and sweet answers I cannot find any data or studies on this one. It may be obvious to the educated in the field.
The situation is that I have a client in the quarry industry that is running a 930 KW CAT genset.The unit is D399. Roughly 20 years old. The rated amps output is 1460 at 460 volts. Normally during curshing I am running about 600 kw and peaking for a minute or so at 750 KW. My power factor is averaging around 70 percent. During different grades of rock and summer time abient temperatures I have been blowing fuses on the genset. The CAT people have recently found the voltage regulator to be a little flaky and was replaced. My average phase current is 1100 amps with peaks to 1450 for 10 second while a big rock may be in the jaw crusher. Now the genset seems to go right on thru this peak without any problem. My concern is when we start crushing the harder aggreate again the genset may not be able to keep with the contiuous demand.
The question is will installing KVAR power factor correction banks on some of my bigger 300 and 200 hP motors relieve the generator from working harder and even lower loading and/or save on fuel consumption.
Thanks to all that can direct me to a link to fill in the blanks. I am concerned that I do not want to over excite the stator on the genset and will make provision to shed the Kvar as motors are taken off line. We may go to auto cap banks if I can calculate any savings in either one of these areas.
Rick Talbert
Centrix Industrial
Rick Talbert
Centrix Industrial
