chjura
- Dec 2, 2003
- 6
There are two different cases:
The first is when the rotor is radially shifted constantly. This gives an excitation force acting with twice the rotating frequency. However in reality the misalignment is so small, that this force can be neglected. (???)
The second case is more complicated. Due to the operating
deflection shape of the shaft you have a dynamic "eccentricity" which also leads to these forces. If this is developed behaving linear with the deflection it can be expressed as a negative stiffness and is a part of the system properties. Since the change of air gap in x-direction also causes a change of the air gap in y-direction, we probably also have cross coupled terms.
Unfortunately I do not know the formulas to model those two effects.
So the questions are:
How to model the influence of the generator air gap exitation?
Based on which parameters it could be decided that the effect of the air gap could or could not be neglected?
Thanks in advance.
Jura
Thanks in advance.
Jura
