jg79838
- May 13, 2003
- 2
Windows XP
Autocad 2002 - No Modules, add-ins, etc
I have 3 sets of data each consisting of approximately 1400 3d (x,y,z) points. I've loaded the data using a script file and the command "point x,y,z". The 1400+ points represent the surface of a 20-5 ft tall wall. Is there a way to generate a surface (-can't use 3dsurf or similar because points are in no particular order) for ea set and more important compare one set to another to determine if movement has occured?
Thank you.
Thank you.
