Generate DXF file
  • Thread starter Thread starter LittleTome
  • Start date Start date
L
LittleTome
Guest
Hi, all
We can save drawing as DXF file and there are many export options to chose. At the same time we can use ProOutputFileWrite() to do this work, but I don't know how to use arg1, arg2 and arg3. Can we use the three args to implement the exportoptions like use" Save a copy..." ? Look forward to your replies. Thanks!
James
A simpler option may be to create a mapkey of saving as a DXF, and making it a toolbar icon.
NOOOOOO! Bad robertib, bad!
As a rule of thumb, if you can do it in Pro/TOOLKIT don't resort to using a mapkey. Mapkeys are too volatile between revisions and builds of Pro. Look at the documentation under Pro/TOOLKIT Objects->ProOutput->ProOutputFileWrite. It has a detailed explanation of which arguments you can use for a dxf file. Here is a code example I wrote for a dxf file:
pro_error = ProOutputFileWrite(pro_Drawing, pro_DxfFileName, PRO_DXF_FILE, NULL, NULL, NULL, NULL);
Patrick
