cherry2000
I need to generate Data sheets using a Template filled with some generic and some customised information. The customised information is filled in a seperate Database file with a file name. The customised data field is also highlighted in red in the database. Now all the macro needs to do is :
(initially user opens both the sheets..template + database)
1. search and replace all the red fields with data taken from the database
2. save the file using the filename given in the database
3. again repeat the process for the next row of data in the Database
I am attaching both the sample files, for reference.
If somebody can help with the Macro, I will be grateful.
This will be great tool for generating multiple data sheets.
