TimGow
- Nov 24, 2010
- 3
I would like to model the connecting-rod from a crank-slider arrangement, and include the loading that tends to bend the connecting-rod due to acceleration, the dynamic body loads. The connecting-rod is in general plane motion as one end is rotating while the other end is reciprocating. Angular velocity, angular acceleration and linear acceleration can be calculated for particular positions on the connecting-rod, for the crank position of interest.
In FEA I can apply the reaction loads at each of the two bearing pin connections and I have linear acceleration (grav) and centripetal/centrifugal loading possibilities. I am seeking a method that achieves both lateral and axial loads at the pin connections. I could achieve the correct linear acceleration at one location, say the CofG, although elsewhere magnitude and direction would be incorrect. Perhaps there is a combination of linear and radial accelerations that would approximate the general plane motion.
Is there an established scheme for approximating the body loads in a static analysis?
Do you know of a technical paper discussing this topic?
Tim
Tim
