Hi everyone,
I am currently working on the modeling of the railroad track. In my model, I have simulated the rail and the crossties by beam elements and used connectors to add longitudinal elastic and friction elements. The rail is pushed by a concentrated force in axial direction.
I am seeking to see the different slip interfaces by changing the loading rate. Therefore, I have used dynamic analysis and added lumped masses. Right now, the slip is only occurring at the interface with lowest friction resistance (tie-ballast interface).
Any idea how I can change the slip interface disregarding the friction resistance and make it only dependent on loading rate (simulation time duration)?
There are some figures below to clarify.
Thank you.
Thank you.
