Looking for input as to which of the two notes below show the most promise for Basic Dimension measurements in Model Based Definition files
1 ALL UNSPECIFIED DIMENSIONS SHALL BE QUERIED FROM THE MODEL AND CONSIDERED BASIC.
QUERIED DIMENSIONS MUST BE TAKEN BETWEEN THE MEASURED SURFACE AND THE APPLICABLE
DATUM REFERENCE FRAME. QUERIED DIMENSIONS SHALL BE ROUNDED TO THE SAME NUMBER
OF DECIMAL PLACES AS THE APPLICABLE FEATURE CONTROL FRAME.
or
2 ALL QUERIED DIMENSIONS SHALL BE CONSIDERED AS BASIC WITH A “MEAN VALUE” UOS.
DECIMAL PLACES SHALL USE THE SAME NUMBER OF PLACES AS THE APPLICABLE GEOMETRIC CONTROL TOLERANCE.
MEASUREMENTS SHALL BE TAKEN FROM THE RELATED DATUM FEATURE TO THE MEASURED FEATURE.
UNIT OF MEASURE SHALL BE THE SAME AS THE MASTER MODEL DEFAULT UOS.
