Dears,
I would like to know what happened when a gearbox rotate from output instead of from input?
I know it is harder to rotate gearbox from output instead of input, however I don't have any value.
there are cases that the motor is off, however the machine can rotate the gearbox because of inertia or other sources. Does it make damage to gearbox?
Is there any value how much power needed to rotate a gearbox from output?
