cadastrophe
- Nov 29, 2002
- 36
I have decided I'm fed up with neutral between first and second gears, and will
re-mortgage my house, give away my first born child, and sell my soul in the
pursuit of having a truly sequential 'box!
Is there any reason a new selector drum couldn't be carved to this end? If so, what's involved? Anyone ever machined a selector drum?
It would make life a lot simpler and less risky for those like me who use
electric/air shifters. I have removed the neutral detent and spring to avoid
grabbing neutral when shifting by button. It makes things somewhat awkward
trying to select neutral in the pits though!
I'm not too good on gearboxes, which will explain the next
question.
Has anyone modified either 1st or top gear to act as reverse? I know some
quads have a reverse gear in a motor that's not too far removed from it's
two-wheeled-no-reverse cousins. Yet on the other hand, AFAIK, the Goldwing
has an electric reverse, which seems odd for a megalith which has everything
else under the sun fitted, and isn't apparently concerned by gross weight.
Am I right in thinking that one or more models of BMW have a reverse gear?
question.
