sanjaychetan
HI,
IN VARIOUS GEAR DESIGN BOOKS LIKE DUDLEY,RATED TORQUE OF MOTOR MULTIPLIED BY SUITABLE GEAR REDUCTION RATIO IS USED TO CALCULATE THE STATIC STRENGTH OF GEARS OF VARIOUS STAGES OF A GEAR BOX.HOWEVER PULLOUT TORQUE OF MOTOR(SAY SLIP RING MOTOR) MAY BE AS HIGH AS 3 TIMES THE RATED TORQUE.SO DURING STARTING OF DRIVE VARIOUS GEARS WILL BE LOADED TO 3 TIMES THE TORQUE FOR WHICH THEY ARE DESIGNED.SO SHOULDN'T THE GEAR STRENGTH BE CALCULATED ON THE BASIS OF PULL OUT TORQUE OF MOTOR?SOMEBODY MAY PLEASE THROW SOME LIGHT ON IT
