gear motion
  • Thread starter Thread starter juproe
  • Start date Start date
J
juproe
Guest
hi everyone,
I need to make two coupled gears moving, and i thought to some different solutions:
1. to give no constrains between the gears, and use 2 different motors, one for each gear, with the correct transmission ratio
2. to give a friction constrain between the 2 primitive surfaces, as to realize 2 friction gears, using a single motor applied to the input gear
3. to give a contact constrain between the opponent surfaces of 2 teeth, and apply a single driving motor
too easy to be true...
I have no problem in the first solution realization (2 different motors),
But, i don't know how to implement the other 2 solutions,does anyone have an idea?
thank you all
A better solution is to use a Gear Pairconstraintbetween the two gears. In WF2, while in the mechanism mode select the icon that shows 2 gears meshed. This option is new to WF and not availiable in 2001.
Good Luck.
oh! yes, you are right!
i wanted to create a join between the 2 gears in the standard mode, but it doesn't make sense!
thank you very much
