J
juproe
Guest
hi everyone,
I need to make two coupled gears moving, and i thought to some different solutions:
1. to give no constrains between the gears, and use 2 different motors, one for each gear, with the correct transmission ratio
2. to give a friction constrain between the 2 primitive surfaces, as to realize 2 friction gears, using a single motor applied to the input gear
3. to give a contact constrain between the opponent surfaces of 2 teeth, and apply a single driving motor
too easy to be true...
I have no problem in the first solution realization (2 different motors),
But, i don't know how to implement the other 2 solutions,does anyone have an idea?
thank you all
thank you all
