I have a WW2 jeep, 1942 Ford GPW. Recently I edited together a book based on articles from Army Motors. An Army magazine for mechanics and drivers of WW2. It was the precursor of PS magazine that is still being produced today.
One of the articles, "Sore as a Boil About Oil", August 1942, compares gear lube oils. The major concern seems to be the operating temperature inside the transfer case. The lubes discussed were 80-140wt 140-250wt vs 90 wt (0r 80wt for temperatures below zero).
Apparently, the thinking at the time by many was that the heaver oil wouldn't leak thru the leather oils like 80 or 90 wt oil.
The article claims the temp in the case when using 140wt oil will climb and the heat will thin out the heavier oil to the same viscosity as the lighter oil. Thus leaks would still occur. The temp using 140 produced disadvantages...
...tests show that 140 oil causes an operating temperature of 235F to 260F in the transfer case with a resultant viscosity of 90 Saybolt seconds.
...similar test show that 90 oil causes a temperature of only 190F to 210F with the same viscosity of 90 seconds.
...higher temperatures break down the 140 oil...ruins oil seals.
...90 oil, being made of refined oil with a fixed additive, remains stable up to a temperature of 265F. 140 oil is often made up of a poor base stock and separation at 230F is not uncommon - the result is a tarry mess at the bottom and a light, spindle oil at the top. Bearing failure is just around the corner.
... SAE 90 (Federal Specification VV-L-761
...tests took place on a hot day - temperatures hovered around 100F.
So after this long winded post my questions are...
Are there any modern studies relating the operating temperatures of various weights of lube oils?
Modern ads for gear lube claim stability as a selling point in gear lubes like 80-140. One would think that improvements to production and additives would have occurred during the 60 or so years that have passed since that article was written. Is this the guess?
The bottom line? Original specifications called for 80 or 90 wt lube is it safe (from an operating temperature standpoint and any other factors) to use 80-140wt lube?
Many in the WW2 jeep field claim ti use the 80-140 becuase it "keeps the gears quieter" or other reasons. No one has offered any studies to prove using the 80-140 is better than 90.
And as a side question, other than manufacture specifications, how can you determine which engine oil to use? During WW2, Willys and Ford specified 30wt for normal ambient temperatures and 10wt at low temperatures. Today, many in the jeep field claim that 20w50 is best at least for summer time use. Any studies comparing 30wt (or perhaps 10w30 vs 20w50 )?
Thanks.
BobN
Thanks.
BobN
