I have a print from a customer when he only has the straight line distance from one hole (a datum) to the other holes
I know he doesn't care about the gear position per se, just the center distance so that the gear meshes correctly.
I have a CAD model so I can get the XY distance from hole to hole, but can you use TP with just one dimension?
If not what would be the best way to GD&T it without over constraining it?
Thanks,
Robi
Thanks,
Robi
