Mahhu454:
That is an interesting question so I will reflect both the 94 edition and also the 2009.
94 edition
5.10.1 (c) "To invoke this concept, the term BOUNDARY is placed below the feature control frames."
Fig. 5-47 does show the BOUNDARY below the feature control frame.
The standard does not mandate it but emphasizes it for non-round features of size.
2009 edition
7.4.5.1 (c) "The term BOUNDARY may be placed beneath the feature control frames, but is not required."
Fig. 7-34 reflects exactly the same as the sketch with the term BOUNDARY.
Without a checking fixture, we must confirm the boundary has not be breached. On the .281 width, we must check the full width of the 2 flats using our calculated tolerance. In other words, contact on various spots along its length and then use the calculated tolerance, in our case, of +/- .008.
On the radius ends, we must confirm it at its furthest length or in the center using a calculated tolerance, in our case, of +/- .0135.
Of course, a checking fixture is best here.
Dave D.
