GD&T Dimensioning 1
Jashe
Automotive
I'm putting a feature control frame with a vertical dimension and I want it to go right under the dimension. Problem is I can't trim off the dimension line to where it won't go through the control frame. Is there a way to do that? I've attached a power-point to help show the issue.
insert a space in the text under of the main value.
This will give you just enough room... wish I knew a better way.
download.aspx
Eric N.
Clever. Thanks.
I wish you could embed GD&T into any type of text like in NX. I wonder if it is the same in V6?
Tarator: How do you embed GD&T to a vertical dimension in NX?
