I need assistance clearly defining the allowable "twist" of a 3-lumen extruded tube. The extrusion has three holes that run the length of the part, and the twist of the part (e.g. hole pattern rotation from one end to the other) may not exceed +/-15deg over the length. It's almost like defining the allowable rotation of the "pattern" of holes from one end to the other.
It seems as though using the tube end face as datum A, hole #1 as datum B, and then assigning positional tolerance to hole #2 relative to datum A &B would get me closer to locking down the pattern, but I'm a little stumped on this one. Thanks!
