Maxvolonte
Petroleum
Colleagues greet you again and excuse my insistence. What happen is that I started working in another refinery, and the truth is that I do not like the way they are handling things here. My new doubt, arises because the purchasing department, bought a lot of gate valves from two different manufacturers, one local here in Argentina, and the other KSB of China. It turns out that both valves are trim 5 of 3/4 "S 800 SW, but the local brand, the valve body is a thick as a series # 6000 accessory , when the body of the Chinese valve is almost half as thick, as a series accessory # 3000. My query is, it is this normal, to the thickness variation from a brand or manufacturer to other? It happens that the contractor is using both type of valves in the same prefabricated pipes, same service. Any suggestions will be appreciated.
Attached photos,
Best regards
Attached photos,
Best regards
