Hi. I am currently working on a geothermal project that will drill new Wells to be hooked up to the existing SGS (steam field gathering system). I have a query regarding the utilisation of gate valves as flow control though I understand that these type of valves are not designed to control or regulate flow. Reason i am asking this is, we initially considered a triple offset butterfly valve as a means to control flow , apparently large pressure drops are expected, at this type of valve, even at full open condition. For geothermal operation, large pressure drops results to lower productivity/deliverability from a producer well. One of the reasons why we need to control flow at the well is if potentialy we encounter a surging flow type of well (which we have already experienced) which could result failures on our cross country piping, and issues on our brine production management at our downstream facility.
My question is, if we are to consider a gate valve as means to control flow (this is downstream of slab type gate valve) which we consider as a sacrificial valve, would a wedge type be better as compared to a slab type one (considering cost, ease in operation and longevity)?
