Gate valves for LNG
1BT
Nuclear
Jan 22, 2004
17
could you help me to find a valve supplier in the UK or europe for 8 x 6" gate valves butt weld ends schedule 40 for use on LNG @ 10 bar temp minus 165 centigrade
Piping Classification Specitication varified shall have the the following Valve for Cyrogenic Services
Description of GATE Valve: (1/2 -to- 24)
Type: GATE (CRYOGENIC TO -325ºF)
Class: 150
Ends: RF FLG
Body/Bonnet: SS (ASTM A351-CF8M)
Trim: 316 SS, HARDFACE SEATS, API 600 TRIM #12
Design: OS&Y
Operation: HANDWHEEL
Bore Port: FULL
Bonnet Type: BOLTED, EXTENDED BONNET FOR CRYOGENIC SERVICE
Stem-Packing: CORROSION-INHIBITED DIE-FORMED FLEXIBLE GRAPHITE
WITH ANTI-EXTRUSION RINGS
Wedge Type: SOLID or FLEXIBLE WITH CAVITY VENT TO HIGH-PRESSURE SIDE
Gaskets: API 600
Bolts/Nuts MFG STD
The standards are:
DESIGN - ASME B16.34
ENDS - ASME B16.5
RATING - ASME B16.34
Leonard Thill
Hi 1BT
Try this co:cambrian valves in the UK They are pretty good at sourcing specials. Their email is cvalves@aol.com
Any advise on where to purchase ASME B31.3 in the UK.
1BT
Poyam of Spain
Orion of Italy
have a good product line for LNG valves
Raimondi (now part of Tyco) used to do them but this line I think has been pass to the Fasani plant (again Tyco)
1BT,
below you can find all the adresses of the Italian Companies mentioned by JGPeck:
* RAIMONDI
Via Castellanza, 47
20027 Rescaldina (MI) Italy
Ph.: +39 0331 575111
Fax: +39 0331 464772
E-mail: raimondi@raimondi.it
* FASANI
Via Simonotti, 20
28010 Briga Novarese (NO) Italy
Ph.: +39 0322 94333
Fax: +39 0322 94964
* ORION
Via Caboto, 8
34148 Trieste (TS) Italy
E-mail: orion@orionvalves.com
Hope this helps, 'NGL
