Gate Valve 1
yvonne
Industrial
Sep 14, 2002
22
Hi
I need a cad drawing of a 6" gate valve
2d or 3d
thanks
Yvonne,
Parallel Slide, Wedge Gate or Thru Conduit?
Pressure Class?
Flange type - RF, RTJ, BW etc
Manual, Gear or Actuated?
Cad format ? dwg or dxf format can be supplied without any problems.
Lastly, what do you intend to do with this drawing
Hi
The gate valve I had in mind is a parallel slide
manual format DWG
My use for the drawing is a project I am doing at college
as part of my research into cad
You can post your address on this site or e-mail me direct and I will forward you the drawing you require.
vduffy@weirvalve.com
