Hello All,
Although my background is in engineering, I'm definitely "green" when it comes to pressure vessels, so I thought I'd reach out to the experts for a little guidance. Basically, I have been tasked with getting a very large horizontal pressure vessel ready for re-certification. I'm mostly looking at replacing all of the blind flanges, gaskets, nuts, bolts, etc... The vessel is very large (~30k gallons) and is only actually filled and pressurized (with water @ 150 psi) during testing. Most of the flanges already welded to the vessel are 2" 150# SA 105 RF, although a lot of the blinds I have been pulling off are actually FF. So my first question is, shouldn't RF flanges also be mated with other RF flanges? Also, is it recommended to only use ring-type gaskets with RF flanges instead of full face gaskets? The only reason I'm considering full face is that they seem like they will be easier to align and keep in place during assembly. Also, how do I go about determining what type of bolting configuration to use (studs, bolts, lock washers, etc..)? Is the normal process to select the type of gasket that will best suit your system's needs first, then to calculate the minimum preload required to seat that gasket along with containing the internal pressure (Wm1)?
Thanks in advance. Any and all information is appreciated!
