On-Line washing causing cracks is not hearsay - its Fact! There is a very famous case of a user who on-line washed for two long and it was a major factor in blade liberation of the first stage blade.
I won't go into detail, but it cause lots of problems for lots of people, not least as the design was upgraded as a result, which turned out to cause more problems than it solved!! But that's another story.....
I think the answer given by 'GTSTARTUP' is the most practical approach, i.e. was for 20 minutes or so and the ambients will not have changed by much and do a compare of the results, even correcting will not be necessary in this instance, as long as you look at gross power. Finally, its important to on-line wash regularly after a compressor clean (either off-line or hand clean), as once the dirt is adhered to the blade and vanes for too long, on-line washing has minimal affect.
Good Luck.
