In my job, I'm learning about a gas recovery plant, this plant have three absorbers, in the first, gas feed is a C5- mixture. All C3+ are removed by absorption with naphtha. Top product is C2-
The question is, in 2 desing I've noted that the feed (gas & naphtha (liquid)) temperature inlet is lower than temperature outlet products. Is like heat generation occurs. Why is it? Can I talk of mixture heat in this process? May be absorbtion heat? Why, If I have ligth hydrocarbons? How can I explain it?
In my PRO/II simulation, this not occurs, there the gas effluent is colder than gas feed and the liquid effluent temperature is hotter than inlet. Like I think that would be :-/
What most be changed in my simulation to make in consideration this heat generation? How can I simulate it?
Thanks,
Lblopez
Thanks,
Lblopez
