Axial Flow Fans are OK, but how about the noise ? That is a serious disadvantage. If the area is not too large, just look at some simple propeller fans (wall mounted) which when located properly will do the job admirably at fairly low noise levels. All would depend upon your layout, area etc. If it is a large area and you are looking at Ducted layouts, go with Cabinet type Centrifugal fans which can be ceiling suspended.
