Garage Slab on Grade Joints
StructuralEd
161
Does anyone provide slab to slab dowels for slab on grade garage floor slab joints?
I've recently seen a highway slab detail that provided smooth dowels but it seems like that may be related to frost movement and heavy repeated loading.
For a parking structure SOG we detailed a 1/2" dowel with one side greased. At construction joints with light loads, you could probably get away with just a keyed joint. But, you definitely want to prevent relative vertical movement between slab edges. A shift in height will create a tripping hazard as well as an increased impact stress when the vehicle rolls over it. Soil under SOGs are not typically homogenous.
For large equipment garages i have used load sharing dowels. Fire Stations and military garage.
This thread might benefit from more clarity regarding what "garage" means. House? Commercial? Mining vehicle storage?
