Hi D,
See you into Structural design....
I do not know where in the world you come from but,
I work in South Africa in the cheaper residential structures and galvanizing are often prompted to be expensive and "the ordering of it" time consuming, therefore we paint most of our structural steel work,
that is often not the case with bigger projects thou,
however, the Galvanizing society had a huge marketing thing going on and they have compared the two systems and therefore I think I understand the differences,
Painted methods need more maintenance and application is important.
Galvanizing need lessor maintenance IF DONE AND INSTALLED CORRECTLY and therefore is cheaper over time,
Galvanizing is a chemical method while painting is a mechanical method – the paint get “sucked” to the steel,
Preparation for paint is done by sandblasting to remove slag - that is never done over here anyway, and the slag is burned automatically when galvanised
The design calcs is the same as strength are not influanced (I do not know if this is true with all grades of steel)
Tx for giving my 2 cents
