Galvanized surfaces : Dross acceptance criteria
Taoufik Sbai
Automotive
Feb 16, 2024
3
Hello
For an automotive application, i have to set the boundary acceptance for dross / dross inclusions per unit surface area.
The only input that I found for says med dross less than 2mm are acceptable (Surface EUC 7 Standard) without referring to any quantity.
I will appreciate any guidance for this topic
Hello all,
Is there any standard document that can be used ? ASTM 123 and ASTM 653 (Hot dip) don't refer to any Quality appearance criteria.
THanks in advance :)
