connectegr
Any suggestions?
A project with completed erection, with many connections designed as Class A slip critical. The project is galvanized, so the coating is not Class A certified and the coatings are not blocked. What can be done if the erector failed to wire brush the faying surfaces?
The required slip coefficient is 0.33, for Class A. I think galvanized surfaces without wire brushing are approx. 0.15.
Some of the connections have OVS holes, so "bearing" connections are not an option. And they are not overly conservative to account for the difference in mu values.
