gabimo
- May 2, 2013
- 124
As per Y14.5 and Y14.43 theory a physical hard gage cannot be designed at LMC.
Our designer said, if the size tolerance is taken from the position tolerance then a gage CAN be made at LMC and be a valid inspection method. Is that really true?
Example: 500±.005 (hole)
Pos Ø.015 LMC to A, B, C
Gage to be pos Ø.005 MMC to A, B, C (size tol. ±.005= .010, .015 - .010 = .005)
What are your thoughts?
Thank you
Gabi
Thank you
Gabi
