I have a small 240VAC motor which I believe has a faulty start cap. When the motor is first started it runs fine, but when it it stopped via a separate control limit switch and the contactor drops out, if the limit switch is closed again the contactor will re-energise but the motor will not start again in that direction. It can however be switched in the reverse direction. This occurs no matter which direction is engaged initially, once the limit switch has stopped the motor, it will not re-start in the same direction. The installing electrician has wired the motor with no protective earth, is it possible that this has in some way affected the operation of the capacitor or is that unrelated (just dangerous!!!!)
thanks
thanks
