Manolo:
Vacuum, in the truest sense, should be measured in Absolute pressure. This is a pressure value measured from absolute zero pressure, i.e., from an absolute vacuum base starting point. Note: often some scientists and engineers are delinquent in using the term "vacuum" when they mean a negative value from the base point of atmospheric pressure. This is often results in confusion and misunderstanding. Absolute pressure is the recommended usage because it is precisely that - absolute.
Here are the equivalents of vacuum measurement units:
1 Atmosphere = 14.696 psia
= 101.325 pascals
= 760 mm mercury
= 760 torr
= 760,000 microns mercury
= 29.94 inches mercury absolute (@ 32 oF)
1 Bar = 14.5 psia
I hope this helps you out.
Art Montemayor
Spring, TX
