Full R meaning
Manuel061072
Industrial
Oct 22, 2013
4
Who can help me to interpret this requirement?
Thanks!
FULL R means Full Radius.
However, while your image is too low resolution to be sure I'm not sure they're showing a full radius.
I appreciate your help KENAT!
And what about .005 max. flat (optional)?
Thanks.
I always thought that FULL R required both edges of the radius to be tangent?
Not sure what the .005 MAX FLAT (OPTIONAL) means.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
My guess is that the "FULL R" can be such that it leaves a .005 max diameter flat at the center (FULL R +.0000/-.0025?).
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Manuel061072,
I think whoever prepared that drawing was confused.
I have seen "FULL RAD" used to show that the round thing at the end of a slot was a radius with R being half the width of the slot. Today with ASME Y14.5, you must mark it with an "R".
Perhaps the drafter means "SR", meaning that it is a spherical radius of some sort, as per ASME Y14.5.
JHG
Thanks for all your comments!
I am sorry I am not more clear since English is not my native language
Regards.
Do you speak Spanish?
John Acosta, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
SR would be correct except for the allowable flat.
-Dalai Lama XIV
My guess would be a the intent is an SR with the option to leave a .005 max diameter flat at the center (FULL R +.0000/-.0025?) as ewh suggests, or possibly a flat that is cut back a distance of .005 from the theoretical perfect form tip as another interpretation.
