Hello valve gurus,
Do you think Full opening check valves are supposed to be installed horizontally too?
Clearance between body and disc is very small for these valves compared to regular swing check valve.
Any little intolerance at the hinge pin joint will cause the disc to drop a little on the body.
Any of you came across such problem before?
Thanks in advance
Thanks in advance
