In general, it means that area cut out of the shell or head to insert a nozzle is replaced by a similar area as reinforcement. Specifics vary, as noted above.
In some cases, they want nozzles reinforced so that maximum allowable pressure is not limited by nozzles.
I believe there is a code case that allows less than full nozzle area replacement to be used, also.
