full list of "hotkey" combination
eawagner
12
I would like to find a full listing of hotkeys/menu accelerator key combinations for NX2 and NX4. I have looked through the help documentation and cannot find a full listing of keystroke combination = function type listing.
Has anyone ever come across this type of list? If so, where might I find it?
Thanks in advance.
I can't help you out with UGS NX 2 since we didn't add this feature until UGS NX 4, but you can now go to Tools -> Customize... and when the Customize dialog comes up select the button at the bottom labeled 'Keyboard...' and when that dialog comes up, select the button labeled 'Report'. That should give you what you're looking for. Also note that that last dialog is where you can edit and/or add your own keyboard (hot-key) commands for whatever function you wish.
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
Here is my list of Shortcut Keys in NX2. Most of them are from a list I got from Cadpotato a few years back and the last 3 were added in WF3
KEY; Function
Ctrl-B; Edit, Blank
Ctrl-C; Copy
Ctrl-D; Delete
Ctrl-E; Tools, Expression
Ctrl-F; Fit View
Ctrl-G; Grip Execute
Ctrl-I; Information, Object
Ctrl-J; Edit, Object Display
Ctrl-L; Format, Layer Settings
Ctrl-M; Application, Modeling
Ctrl-N; File, New
Ctrl-O; File, Open
Ctrl-P; File, Plot
Ctrl-R; View, Operation, Rotate
Ctrl-S; File, Save
Ctrl-T; Edit, Transform
Ctrl-U; Execute User Function
Ctrl-V; Paste
Ctrl-W; Application, Gateway
Ctrl-X; Cut
Ctrl-Z; Edit, Undo
Ctrl-Shift-A ; File, Save As
Ctrl-Shift-B ; Edit, Blank, Reverse Blank All
Ctrl-Shift-O ; Format, Layout, Open
Ctrl-Shift-C ; View, Curvature Graph
Ctrl-Shift-D ; Drafting
Ctrl-Shift-F ; Format, Layout, Fit All Views
Ctrl-Shift-S ; Tools, Macro, Step
Ctrl-Shift-G ; Debug Grip
Ctrl-Shift-H ; High Quality Image Part
Ctrl-Shift-I ; Information, Object
Ctrl-Shift-J ; Preferences, Object
Ctrl-Shift-K ; Edit, Blank, Unblank Selected
Ctrl-Shift-N ; Format, Layout, New
Ctrl-Shift-P ; Tools, Macro, Playback
Ctrl-Shift-Q ; Quick Shaded Image
Ctrl-Shift-R ; Tools, Macro, Record
Ctrl-Shift-T ; Preferences, Selection
Ctrl-Shift-U ; Edit, Blank, Unblank All Of
Ctrl-Shift-V ; Format, Visible In View
Ctrl-Shift-Z ; View, Operation, Zoom
Ctrl-Alt-B ; Tools, Boundary
Ctrl-Alt-C ; Tools, CLSF
Ctrl-Alt-M ; Application Manufacturing
Ctrl-Alt-N ; Tools, Unisim
Ctrl-Alt-W ; Application Assemblies
Ctrl-Alt-X ; Tools, Lathe Cross-Section
Alt-Tab ; Toggles Application
Alt-F4 ; Closes Active Window
F1 ; Help on Context
F3 ; View Current Dialog
F4 ; Information Window
F5 ; Refresh
F8; Closest Orthographic View
Home; Trimetric View
End; Isometric View
[wavey3]
In Drafting when you are dimensioning a part.
Right arrow; text to the right of dim
Left arrow; text to the left of dim
Up arrow; text above dim
Down arrow; text below arrow
Numbers on key pad; Trailing Zeros
E; goes strait to annotation editor
S; goes to dimension style
Mike: Here is my list of Shortcut Keys in NX2. Most of them are from a list I got from Cadpotato a few years back and the last 3 were added in WF3
Just remember, UGS products at least work at the initial release. PTC products take until M100 before they are stable enough (out of user beta testing) to be used in production.
Ben Loosli
Sr IS Technologist
L-3 Communications
UGperson,
Good tip I've used those as well since they were introduced in "NX2".
I also forgot the ones for the selection tool.
G Select Geometry
F Select Features
C Select Components
Isn't there also a shortcut in drafting
T Tolerance type?
Michael
[frog]
G Select Geometry
F Select Features
C Select Components
For NX 5 those have changed slightly. Now they are no longer modes, but rather priorities and there are now 5 of them:
F Features have priority
G Faces have priority
B Bodies have priority
E Edges have priority
C Components have priority
Remember, since these are NOT modes, nothing is filtered-out. That is, all objects are selectable, just that you can change the priority as to which object type gets selected ahead of otehrs if there are more than one type inside the pick circle.
John R. Baker, P.E.
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
