ppmsb
The event of the Fuel Gas Heater trip/fail is not necessarily detrimental to the GT if only occurring a few times. If the unit is setup correctly and depending on the unit model, for example a GE 7/ 9FA+e would simply perform a runback to a minimal pre-selected mode and load. However there are users out there that, to save money and not necessarily affect their trip counters for maintenance factors, use this method of shutting off the Fuel gas heaters to respond quickly to dispatch orders giving them the ability to shut the unit down quickly. This method does save time and fuel verses a normally regulated shutdown however they do so at the cost of Combustion Hardware and reliability issues as this practice causes higher than normal thermal stresses in hardware. Many operators assume that the OEM’s do not know that this is becoming a common practice and frequently attempt to blame reliability issues and hardware damage on the OEM’s under the guise of warranty claims. However I can assure you that the OEM’s are aware of this practice and may quickly dismiss warranty claims, as this practice is easy to spot in the control data.
Romefu12
