Fuel Gas Purge Fow Rate
wiseguy007
Chemical
Dec 1, 2012
Hi Guys,
Does anyone know how to calculate the fuel gas purge flow rate required for a horizontal cold vent open to atmosphere?
So far the only information i can find is realted to vertical flare stacks (API 521). Can these formulae be applied for my case as well? If not, how can i proceed with the calculation?
Thanks.
I assume that this is not continuous purge. I assume that this is start up or maintenance purge. In any event, if the purge is continuous you could use the correlations in API 521 but I cannot envisage a scenario where one would continuously vent fuel gas to atmosphere without at least flaring it.
This is a case of continuous purge. Gas is routed from the production header to vent header where there is a knock out drum.
