Guys,
is there any way to calculate how much fuel gas (MMSCFD) I need to have for example 1.4375e+07 Btu/hr of heat flow. The gas composition/temperature/pressure are known. I'd like to do it through the Hysys as the mix is very complex.
Certainly I can comply the material balance and then to calculate the heat of combustion for each component (USING THEIR ENTHALPY). Or there is the easier method to calculate the total combustion heat?
thanks,
Joisy
thanks,
Joisy
